Purchased used 2011 Kia Soul Plus with 2.0 L engine with 95,000 miles
1 reading
3.3K views 3 replies 2 participants last post by  KRV4Lee
#1 ·
I am wondering what problems other Kia Soul owners have noticed around 100,000 miles. I have read that the crank position sensor goes bad for some. My brake lines and suspension parts are all rusted due to the heavy use of salt on snowy roads in Ohio. It runs good. I just cleaned the throttle body and found a little oil in there which is odd. Spark plugs look good. Mileage is good. Idle is at spec but does move around a little bit suggesting carbon build up in IAC (idle controller) or something else going on. If anybody know of where to get the Factory Service Manual, that would be great as well. I always get the actual books vs the software but either would be better than nothing.
So far, I had to...
1. Add coolant (no leaks found though)
2. Replace wipers (rear is hard to find so I let it be)
3. Change the oil, cabin filter, engine air filter (cabin filter must be deformed to get it in)
4. Cleaned the throttle body (3 filthy wipes)
5. Reseal two tires and rebalance (brand new tires so that was odd)
6. Put stick on mirrors to cover blind spots
7. Put anti-seize on back of all the wheels
8. Get wheel alignment to correct front toe
Frank
#2 ·
I replaced idle air valve and made a world of difference in smoothness at stop lights. I added a fumoto sx drain valve and no leaks! No room to get proper torque to drain due to the car being so low to the ground, so just easier with drain valve. It swivels so I can point it at my oil jug and go watch tv while it is draining. I had to reseal every tire because whoever put the new tires on apparently didn't seal them at all. Overall, very smooth and engine is powerful. It is kind of jumpy when I first press on the accelerator, but I am getting used to that. I feel every bump and hear a wobbling sound when on the highway, but I think it is likely the tires doing that. If it were the cv joints if would get worse around turns. Hopefully, not the bearings. Those have to be pressed and that would be too expensive to do right now.
#4 ·
You've had it for a year and a half I guess. How many miles now? If these are the only issues with an older car, it does not sound bad. I figure with an older vehicle you should just budget for repairs so you're not surprised, and hopefully you have no car payment.
Drive safe. (y)
