1 - 1 of 1 Posts
ProCeed 2012 ED, 1.6 CRDi 66 kW
So it's been below freezing for well over a week and last Friday I suddenly noticed that the instrument cluster in my car is no longer working properly; all gauges (tacho, speedo, temp, fuel) stay at 0 and the digital odometer display is off. Not just blank, but off entirely. Backlight also isn't working. I can't tell for sure if all the indicator lights are working but for the most part it seems they are. The car starts and runs fine otherwise.
I already checked the 10A CLUSTER fuse and it was fine. I also disconnected and reconnected the negative battery terminal in an attempt to reset the system but it had no effect. Is there anything else that I can try? I don't really have the time to take the car in for diagnostics right now but driving around without a working speedo doesn't seem like a good idea either.
1 - 1 of 1 Posts
