Cee'd & 2010
Hi,
Using driver side multifunction I have observed these problems:
* Left blinking light works randomly
* Lights do not work in dashboard buttons
* Rear lights do no work. The power does not appears to lights (tested).
* Front fog lights do no work
Right blinking lights, headlights, rear fog lights and long lights are working fine. I have checked all fuses and everything seems to be fine too. I tried to find out relay which might cause these problems, but I could not find any relay for this purpose.
Does anyone have an idea what might cause these problems?
Car: Kia Cee'd, 2010
There was a similar problem with 2007~2009 KIA Spectras/Ceratos... The BCM (body control module) was located behind the passenger compartment fuse panel (part of the panel)... It caused all kinds of strange electrical problems and all of yours are BCM controlled...
A used replacement BCM should be "plug and play" and should not require any programing to "marry" it to your car...
I may be wrong on my diagnosis but the advise is "cheap" :)
Cee'd & 2010
I changed multifunction switch of blinking and it didn't help. I didn't find the BCM (body control module). Anyhow this seems to be electricity problem.
