Hi everyone, I need a little help with my car.
The problem is, while cruising on the road, the engine RPM rise unexpectedly then back to normal again... especially while changing gear.
This didn't happened when I rev up while the car is stationary,
I tried to clean the carb, air filter, sparkplug... with no success.
can anyone help me solve the problem
Any information is appreciated.
Thank You
try to change air filter, if still no working please have your carb service (overhauled) and make sure air vacum compression working well. Usually this working out the problem.
recomended timor mechanics (Dwi Suwarto 0816-1318978)
I already changed the air filter, but the problem didn't go away.
I also have the carb overhauled..
as for Vacumm compression.. I'll try later on the week end...
Thank You for the recommended Mechanic... I'll also give him a call
Thank you again....
