1 - 13 of 13 Posts
02 Sportage, 95 Trans Am, 05 Crossfire, 04 Venture
2002 Sportage
About 3 years ago I went to start my Sportage and the idle wouldn't drop less than 1,200RPM. I tapped the accelerator and the idle stuck at an even higher RPM. I accelerated in idle again and the RPMs began climbing and climbing all on its own until finally I had to shut it off. It still does this.
The IAC was making strange noises with the engine off and ignition on so I'd replaced it. I tested the TPS voltage and it checkout out okay. I adjusted the throttle and throttle cable exactly as shown in the service manual. The throttle cable is not sticking. I've also cleaned the MAF.
Its been driven maybe 5 times in 4 years because it's constantly having issues. I don't know if the RPMs drop in gear because I am just finishing up replacing a brake line. Any idea what other sensors could possibly cause the idle to climb on its own like this?
Moderator
99 Kia Elan 1.8L
Elevated idle RPM's potential causes is the IAC or intake manifold vacuum leaks - have you checked for leaks?
What engine? - please add your Sportage model to your profile.
2002 Sportage
2.0L DOHC I4 Gas
Auto Trans
I did replace both the upper and lower intake manifold gaskets before. Good idea. I'll check that out.
+1 w/ Ron - IAC valve, or illegal air are what I'd be checking, if here.
I can't seem to locate the option to edit my profile on a mobile device.
Discussion Starter · #7 ·
I found a small vacuum leak which I fixed. The idle hasn't increased on its own but it idles around 1200RPM. What's the idle RPM supposed to be? My other vehicles are 650 - 750ish.
Moderator
99 Kia Elan 1.8L
Have you checked the function of the IAC?
^^ and IAC gasket, even a pinhole leak will cause high idle. ( IIRC on one of the Sporty's here, I used a thin film coat of Water Pump Gasket ( thin grey ) RTV on the IAC gasket and mating surfaces to seal it up / fix that issue. )
Discussion Starter · #10 ·
I replaced the IAC 3 or 4 years ago. But it was from a junkyard so... But I did clean it out at that time. I'll pull it off and check it out. Thanks guys.
Discussion Starter · #11 ·
I found that the IAC housing was cracked which caused a vacuum leak.
Discussion Starter · #13 ·
I need to lay off the DeWalt 20v 1/4" impact once in awhile. 😀
1 - 13 of 13 Posts
