Just got off the phone with Kia Eastern Region.
I've got an important warning and gotcha from Kia.
Kia will not honor the 10/100 powertrain warranty unless you can prove that you have maintained the car under schedule 2 - Sever Maintenance. They will tell you this due to at least 2 of the items they list.
- Driving in areas where salt or other corrosive materials are being used.
- Driving for prolonged period in cold temperatures and/or extreme-ly humid climates.
Good luck finding somewhere in the continental United States where they can’t say either. Now the dealer service manager already told me that the salt one doesn't apply because it’s internal transmission damage. The word prolonged is defined as, “to lengthen in time”.
Too bad the transmission wasn't as prolonged as the clutch, etc.
Whose ever heard of a manual transmission failing on any car in the last 20 years? :confused:
I've seen plenty manual trans fail. Driver error for the most part. Only one for Kia in the 3 years I've been with Kia.
So, have you done the required maintenance on your trans? I'm guessing not.
2020 Hyundai Palisades
+1 if you have done the required maintenance with proof it should have been no problem and the transmissions are pretty bullet proof as mentioned by cobra259.
10 Optima LX, 12 Sedona LX
There is probably more to this story that the OP failed to disclose. I highly doubt they denied a claim based on those 2 items alone.
To the OP. How about some info?
What year and model?
How many miles?
Are the first/original owner?
Mark,
what maintenance is required on M/T? Pretty much none.
Some are life-filled, or may need oil change (not even flush) after 60k or 90k miles. Hence I do not see place for sever or normal use here.
Failure could be only due to abrupt shifts or internal damage.
