trying to take the main control for the window switch out on my kia sportage and the directions say that i have to put two fingers in the hole and release the switch. well it doesn't work probably because i don't know what i'm looking for. if any one can help i would appreciate it. my window in the rear doesn't work and i figure that it is in the switch.
Removing a switch
I was just working on my window motor today, and had the door panel removed, there are spring clips on either side of the switch front and back that needs to be compressed in order for switch to come out. I know it may seam like allot of work just to remove a switch, unless someone has a better idea but the panels come off very easy and go back on just as easy
the panel won't come off unless you have the window control switch out. Not unless you released the bottom and went up that way. Instuctions say that you can release the window control panel by insterting you hand into the door closurer hole. I just haven't figured out how to do it.
