Hi everyone, the other day as I passed in front of my girlfriend rio 5 I heard a noise, I opened the hood and it was the steering pump.
It’s starting to make a very small noise.
I decided to get some PSF3 as per the user manual call for.
The dealer gives me power steering oil. I asked about the 3 (PSF3) and he didn’t know and he told me that it’s what they used.
I get home and decide to remove the pump but didn’t unplug the hose, it seems to be from inside the pump and not the bearing.
So I told myself to reinstall since I don’t have the necessary parts for rebuilt and replace the fluid. Does anyone know the bearing and parts numbers need to rebuilt?
I remove the most I could from the tank and its red like ATF, but when I open my first bottle its transparent to light yellow like cooking oil.
So the mystery is, did they add ATF or replaced the steering oil with ATF when they use to serviced or is the power steering oil they give me the wrong one?
I have added one bottle as I only had removed one bottle in quantity.
Anyone had a problem like this?
Are these two oils compatible with each other?
Thanking you in advance for your opinions.
