Hello everybody,
The power outlet #3 (in the rear) does not have power. The fuse is fine, to assure it is not playing tricks on me, I swapped it with one of the other 2 ones (outlet #1/#2), they both still work (if ignition is on), but #3 remains dead. I even tried it with the engine running.
Everything else is working fine. There are no apparent signs of someone molesting either the fuse box or the rear outlet. The owner's manual does not give any valuable information, it does not even state that the ignition has to be on before the outlets are being powered, there is no mentioning of a switch. Never seen a switch for a power outlet, but you never know.
Did anybody experience this too and maybe have a solution?
I will take out the outlet this weekend and check the wiring to it, just to make sure power is there. Maybe it is just a bad outlet (wishful thinking).
Thank you!
Thank you!
