Hello,
I own a 2011 Canadian Edition Sportage EX that does not have power folding mirrors and non push start. They were not a option in 2011. I have obtained the mirrors and inside driver side switch panel with the power folding button at low cost new. Is there any one out there that has done a retro fit from standard mirrors to power. The standard mirrors have a 7 wire harness and 7 pins. 2 black wires,white pink,green and blue wire with a black stripe. The power mirrors have 9 pins ( 9 wire harness ) Obviously the 2 extra pins are for the folding option. I partially pulled a power mirror apart and there is also an additional white and blue wire internally.
What I would like to know if anyone has switched to power mirrors and if any one has a wiring diagram. What would be the best way to wire the power mirrors or are there 9 wire harnesses available that I could replace the 7 wire without having get excessive with changing out wire. Or is it possible to add the additional wires to the wire harness that is there now. I have a service cd but it does not have a wiring diagram showing the folding mirrors.
Thanks
Thanks
