Kia Sportage GT-edition CRDI 2.0 -16 // Volkswagen Passat 4-motion -17
No, the Exhaust Gas Recirculation valve (EGR) is not connected to the cooling, it connects a line from the exhaust pipe to the intake manifold.Is the EGR connected to the cooling? i thought that it was only combustion and vacuum. When i look at tutorials i only see the intake and the canals from the EGR that usually are clogged.
If the EGR is stuck open and allowing flow when it shouldn't, you may notice a drop in performance - as a test, you could blank off the EGR.Well i took it apart and could not really find any blockage in the EGR nor the cooling bits. The next step is to take apart the intake manifold and removing the turbo but i did not have the time for this.
I also tested the EGR valve by adding 12v to the system and the valve worked fine.
Dunno why my car is loosing power. Worked fine during the winter but now when it gets hotter it stalls and i loose boost.
hello, I had loss of power problem with mine ceed 2l crdi -08. Kia service changed EGR but same problem.
