1 - 12 of 12 Posts
· Registered
I keep change in my ashtray, I had a coin get behind the ashtray drawer and now it wont close cause of the coin.. Can someone tell me how to get the drawer out so I can remove the coin and then put all my change somewhere else?
I cant find a thing on this and I cant for the life of me figure out how to get the drawer out.
Thanks in advance!!!
· Registered
car
I believe you are going to have to remove the two pieces of plastic trim that runs from the top of the dash all the way down to the console. They are the pieces that have the vents that are on each side of the radio. Once those are removed you should see some screws in the area that you are having issues with. Remove those screws and the drawer should come right out.
Hope this makes some sense to you its pretty early in the morning! lol
Good luck
· Registered
car
I used a small flat head screw driver to pry it off. I wraped a rag around the end of it to protect the interior of the vehicle. (I have removed those panels because I replaced my headunit.) Once you can get your fingers behind the panel to take it off you can let go of the screw driver and finish poping it off with your hands.
· Registered
That website given earlier is under construction. Can anyone else give me pointers on how and where to pry the side trim off to get the drawer out. My military ID is behind the drawer and I need it to get home every night!! Please help!!
· Registered
2003 Kia Sorento
Pry between the bottom drawer and the trim piece. Cover a screwdriver in tape, and "aim" it towards the trim piece you're trying to remove. The drawer will push in some when you do this. When you get it started, just use your fingers to pull the trim and work your way up.
1 - 12 of 12 Posts
