41 - 45 of 45 Posts
Discussion Starter #44
I solved the problem with the camshaft sensor, now I have an error #8 (MAF sensor) and I get error #5, I can't find anything about error #5, does anyone have any idea of this error?
thanks
No idea on the code 5 jackt - although it is concerning that additional codes are "popping up", every time you rehabbing a given sensor component.
If that was happening here, I would suspect poor voltage / or system ground(s) ..
And would take the time to remove battery, clean all primary ground points, and check / clean the ECM ground points on the inside passenger kick panel (on US Models) if here,
then run a voltage check at the MAF connector to make sure proper (+5v) reference voltage was being supplied to the MAF sensor.
Hope this helps, GottaCruise
41 - 45 of 45 Posts
