61 - 66 of 66 Posts
2005 Kia Picanto
Originally posted by wannakia@Jul 22 2005, 05:04 AM
now i get it.....
how much did u pay for the springs ?
does H&R has s suspension Kit for Pica ?
i dunno whether we can get in here in SIngapore (Asia) :blush:
To my knowledge, there is only springs to the Picanto.
Cobra, H&R, Eibach are also to my knowledge the only one, who is making these springs.
Im not sure, but www.h-r.com and search for dealer, should give some dealer in asia.
/ ViCan2
2005 Kia Picanto
Picanto 2009
Hi, I have just discovered your post and you mentioned that the lowered springs were easy to install.
OK, but I am currently trying to lower my 2009 Picanto and I am having trouble removing the front struts. How the hell do you remove that top nut ?! The workshop manual says simply "remove the upper mounting nut", but what is this? There's only a locknut that's on the end of the shaft coming up from the shock absorber below, and this can't be removed because the spring is compressed. I try to unscrew the locknut but it just turns the shock absorber shaft and won't loosen. If you can explain how I get the strut out I'd be very grateful. Thanks !
vielle568
61 - 66 of 66 Posts
