Peeling blackout trim
1397 Views 3 Replies 3 Participants Last post by  C-Trink
I know I've seen this discussed on here before but how many people are having issues with blackout trim my neighbor has a Honda that is 5 years old and his blackout trim doesn't peel. I have 1400 miles on my Sorento SXP. I have three different spots on the car that are peeling.
See less See more
  • Like
Reactions: 1
Yes, I've seen this before. I can only assume that this occurs randomly, as I just replaced my original set of ventvisors last evening, and none of the cladding came off.
Wish I had a helpful response, but.....🤯
I just mentioned this to my dealer on Monday when I dropped my car off for the over-sensitive traction control issue. They ordered the trim pieces and it is covered under my warranty. The first time I noticed this, I caused it by peeling painter's tape off the trim because I was waxing the car. then I noticed it on the "shark fin" that faces the engine, I believe the wind blew it off.
3
Here is how mine looked before. The painter’s tape was masking a HyperDip attempt that did not go so well. They ended up replacing these two trim pieces. The rear glass and trim are apparently one piece and over $700 while the other is a removable under the rear passenger window.
Hood Rectangle Automotive exterior Grille Tints and shades
Automotive lighting Automotive tire Hood Vehicle Motor vehicle
Automotive parking light Car Vehicle Automotive lighting Hood
See less See more
