I just bought a used 99 Sportage with a few issues. My first to take care of is that the front passenger window and the 2 rear windows do not go down. From thye driver's control I can roll them down and then those other window controls will roll the window back up. I am assuming the button on the drivers control at the top is the window lock out but those other controls do not work in either position.
Thank you all.
Check your fuses for the power windows and if they are good, wiggle the switches a bit and see if that triggers them to work and if not that, I can only imagine that you need new switches. (try the junkyard)
2000 Sportage 4x4 , 1998 Saturn SC2
http://kiatechinfo.com/
Go here and join free, this is the Official Kia website. After joining go to " Service Info ", then select " model ", " Year ", " Body Electrical ", " Power Windows " , " Repair Proceedure ". You can get some info here just poke around for fuses.....Good Luck..
