1 - 1 of 1 Posts
Hi guys. I'm in the process of putting a new set of speakers in the doors of my 2002 Spectra LS - the driver side went perfectly, with no problems whatsoever. I went to remove everything the same way on the passenger side (1 screw in the end of the door, one within the handle, and one within the little cup type piece within the door armrest, as well as 2 plastic clips). Everything came out without a hitch. The problem is, now the handle won't hardly budge (it moves on the end closest to the outside of the door, which is where I believe the rods come from, but it won't budge on the other side). I'm wondering if there's something else I should remove on that side (it has power windows and locks, so I'm wondering if maybe the power lock motor is located there somewhere?). I'm not wanting to break it while taking it apart, but other than brute force, I don't see a way for it to happen.
Thanks!
1 - 1 of 1 Posts
