Guys
my 2004 Diesel 2.9CRDi has out the blue started to splutter and give a "check" light on dash.
I've had codes read
P1119 inlet metering valve control
P1120 Electrical govenor malfunction
Looking these up it seems like the Diesel pump unit. I have called a couple of places for advice and prices. Some and saying it will be Delphi pump breaking up. It needs rebuilt/replaced and the whole system needs flushed including tank and the injectors should be replaced/reconditioned. Is this looking correct? One place asked if car was bosch or Delphi pump? I thought there was only Delphi system at this year?
The car seems ok if kept under 2500rpm and seems worse in the cold!
Had Kia prices or £700 for pump and £200 each injector plus vat. Thats over £1500+vat and prior to labour and flush! :( car only cost just over £2000
2002 Sedona 2.9L
Can I ask what tool you used to pull codes as I can not find one and my Check engine light comes on regular and idles at 2700rpm
Thanks
Kevin
