2006 Spectra5 keeps trough code p0507 after replacing the Idle Air Control.
I replaced this after cleaning the throttle body the idle air control when the ruff and flocculating idle came back. Car started out fine after the change. Then as driving the p0507 code came on. I checked for vac leaks with propane. Found none. Drove car no codes. Let idle goes up drops then settle into 980 and 1000. Then after a bit it will through the p0507. HELP!!!!!!!!!!!!
Thanks JV
Thanks JV
It is to understand what you've written, but look for vac leaks or cracked hoses. Make sure there is no leaks on the throttle body.
