1 - 20 of 66 Posts
New Member
Good Morning,
I am experiencing an issue with the car looking for help. I drove my car about 20 miles to work. I stopped at the store, and when I came out, the car would crank but not start. I checked for codes and saw p0106, I cleared the code and the car turned over. I Drove it back 20 miles with no issue. I noticed No performance problems, rough idles, or hesitation. Im going to see if it returns. Looking for what to check, could it be as simple as a bad sensor, before I take it to a mechanic. Thanks!
Here you go! Manifold Absolute Pressure Sensor! You should be able to change out yourself with minimum skills.
Good luck! Let us know how you make out!
New Member
No, i changed the air filter last week. this is been the first major problem i've had with the car. Battery was replaced in 2018
P0106 is actually a 'correlation' code, and is set when two or more inputs are not what the ECM considers to be in agreement with each other. That's why I asked about the battery, because there have been a number of reports from owners of multiple Kia models of 'false' P0106 being set immediately following a battery disconnect.
In any case, the P0106 does not automatically mean the MAP sensor is bad. And in your case, the not starting issue almost definitely could not have been caused by a bad MAP sensor, because the vehicle should always be able to start and run, regardless of what that sensor does. Yes, a bad MAP is likely to cause very poor performance - perhaps even sputtering on the verge of stalling. But it still should always start, even with the MAP disconnected. And IMO it was nothing but coincidence that it started after the code was cleared.
So my recommendation is to monitor for further issues, before taking it to a shop for diagnosis. If it's running well, with no codes stored, it's likely to be difficult (or impossible) for even a good mechanic to figure out what the problem is if there are no active symptoms. Ideally you want the problem to be occurring, or be able to reproduce it, in order for a shop to be able to do productive diagnosis. It would be a big plus if you were able to DIY some testing of your own, but I have no idea if that's something you're familiar with.
New Member
Discussion Starter #7
What would you recommend I try?
First off, if the P0106 (or any other code) gets set again, the freeze-frame data should be read and recorded for subsequent analysis, BEFORE the code is erased. Lots of point-in-time data is available in freeze-frame, including the MAP sensor reading at the moment the code was set. But it's all purged when the code gets erased.
Going a step beyond freeze-frame, a realtime OBD datastream reader will tell you if the MAP sensor is producing normal output, along with providing you with quite a bit of other potentially useful data. Torque for Android is the most popular setup for this, however there are many other choices available as well.
And you also want to be prepared to diagnose a future no-start (with or without codes), should that happen again. I suggest carrying a can of sensor safe starter fluid in the vehicle, and spraying a SMALL amount into the intake, if you find the vehicle cranking but not starting, in order to see if it will start and run for a few seconds on external fuel. This will send you down the correct fuel/spark pathway for additional diagnosis.
Bad performance can be caused by many things, so I can't offer any help without diagnostics on your part, such as the OBD realtime datastream that I mentioned previously. But if you don't want to get into that, then take it to a shop and get their opinion about your vehicle's performance.
New Member
Discussion Starter #11
It was more of a general statement. I ordered a reader that could provide that info as mine doesn’t seem to provide it without an error code
New Member
Discussion Starter #12
PROTOCOL: ISO15765-4 CAN(11bit)
LANGUAGE: English
Fuel system 1 status CL
Fuel system 2 status ---
Calculated LOAD Value 25.9%
Engine Coolant Temperature 134F
Short Term Fuel Trim - Bank 1 -2.3%
Long Term Fuel Trim - Bank 1 4.7%
Intake Manifold Absolute Pressure 10.2inHg
Engine RPM 933/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 16.5
Intake Air Temperature 78F
Absolute Throttle Position 15.3%
Oxygen Sensor Output Voltage (B1-S2) 0.715V
Short Term Fuel Trim (B1-S2) 99.2%
OBD requirements OBD2
Time Since Engine Start 237sec.
Distance Traveled While MIL is Activated 0miles
Fuel Rail Pressure 558.3psi
Commanded Evaporative Purge 4.7%
Fuel Level Input 49.8%
Number of warm-ups since DTCs cleared 1
Distance traveled since DTCs cleared 2miles
Evap System Vapor Pressure -0.327inH2O
Barometric Pressure 30.6inHg
Equivalence Ratio (lambda)(B1-S1) 1.000
Oxygen Sensor Current (B1-S1) -0.00mA
Catalyst Temperature Bank 1,Sensor 1 826F
Control module voltage 14.23V
Absolute Load Value 22.0%
Fuel/Air Commanded Equivalence Ratio 0.999
Relative Throttle Position 5.9%
Ambient air temperature 75F
Absolute Throttle Position B 15.3%
Accelerator Pedal Position D 14.5%
Accelerator Pedal Position E 14.9%
Commanded Throttle Actuator Control 8.2%
Long Term Sec. O2 Sensor Fuel Trim-B1 -0.8%
Short Term Fuel Trim - Bank 1 -1.6%
Engine RPM 919/min
Vehicle Speed 0mph
Oxygen Sensor Output Voltage (B1-S2) 0.700V
Time Since Engine Start 241sec.
Fuel Rail Pressure 569.8psi
Commanded Evaporative Purge 9.4%
Evap System Vapor Pressure -0.458inH2O
Equivalence Ratio (lambda)(B1-S1) 1.006
Oxygen Sensor Current (B1-S1) 0.00mA
Control module voltage 14.21V
Commanded Throttle Actuator Control 7.8%
Short Term Fuel Trim - Bank 1 0.0%
Intake Manifold Absolute Pressure 10.5inHg
Engine RPM 919/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 13.5
Oxygen Sensor Output Voltage (B1-S2) 0.695V
Time Since Engine Start 246sec.
Fuel Rail Pressure 571.3psi
Commanded Evaporative Purge 15.7%
Evap System Vapor Pressure -0.653inH2O
Equivalence Ratio (lambda)(B1-S1) 1.002
Absolute Throttle Position B 14.9%
Accelerator Pedal Position D 14.9%
Calculated LOAD Value 26.3%
Short Term Fuel Trim - Bank 1 1.6%
Engine RPM 920/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 12.5
Absolute Throttle Position 14.9%
Oxygen Sensor Output Voltage (B1-S2) 0.685V
Time Since Engine Start 250sec.
Fuel Rail Pressure 565.5psi
Commanded Evaporative Purge 22.0%
Evap System Vapor Pressure -1.046inH2O
Equivalence Ratio (lambda)(B1-S1) 0.999
Absolute Load Value 22.4%
FREEZE*
There's no recorded data!
its that's not adequate, i ordered another scanner that im waiting to come tomorrow
I don't see anything wrong with the reader you just bought. If you're thinking that the reader isn't showing freeze frame and should be, that's not the case. The realtime data displayed the following 2 lines: "Number of warm-ups since DTCs cleared 1" and "Distance traveled since DTCs cleared 2 miles". This indicates that you erased the codes just prior to capturing the data stream, so there would be no freeze frame data at that point in time.
AFA the data that you posted, everything looks A-ok. However, you didn't mention if the A/C was on, which was the condition you described as producing a 'rough idle'. Another thing you didn't mention is if this rough idle with the A/C on is something new for this vehicle. That's important to know because it's not at al uncommon for a small engine such as your 1.6L to be noticeably affected by the added load from A/C.
New Member
Discussion Starter #18
i just took the car for a drive and im going to start it again in hopes that the problem returns, ill be happy to run the data again, and use the ac this time.
New Member
Discussion Starter #19
Calculated LOAD Value 25.1%
Engine Coolant Temperature 183F
Short Term Fuel Trim - Bank 1 0.8%
Long Term Fuel Trim - Bank 1 1.6%
Intake Manifold Absolute Pressure 10.8inHg
Engine RPM 636/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 18.5
Intake Air Temperature 123F
Absolute Throttle Position 15.7%
Oxygen Sensor Output Voltage (B1-S2) 0.450V
OBD requirements OBD2 Time Since Engine Start 30sec.
Commanded Evaporative Purge 1.6%
Fuel Level Input 47.8%
Number of warm-ups since DTCs cleared 3
Distance traveled since DTCs cleared 9miles
Evap System Vapor Pressure 0.000inH2O
Equivalence Ratio (lambda)(B1-S1) 0.973
Oxygen Sensor Current (B1-S1) -0.08mA
Catalyst Temperature Bank 1,Sensor 1 709F
Control module voltage 14.02V
Absolute Load Value 23.9%
Relative Throttle Position 5.1%
Absolute Throttle Position B 13.3%
Accelerator Pedal Position E 14.5%
Commanded Throttle Actuator Control 6.7%
Calculated LOAD Value 29.8%
Short Term Fuel Trim - Bank 1 -0.8%
Long Term Fuel Trim - Bank 1 0.8%
Intake Manifold Absolute Pressure 11.7inHg
Engine RPM 630/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 12.0
Absolute Throttle Position 18.8%
Time Since Engine Start 35sec.
Fuel Rail Pressure 545.2psi
Evap System Vapor Pressure -0.065inH2O
Equivalence Ratio (lambda)(B1-S1) 0.981
Oxygen Sensor Current (B1-S1) -0.02mA
Catalyst Temperature Bank 1,Sensor 1 710F
Control module voltage 14.25V
Absolute Load Value 29.0%
Relative Throttle Position 8.2%
Absolute Throttle Position B 17.3%
Commanded Throttle Actuator Control 9.0%
Calculated LOAD Value 36.5%
Engine Coolant Temperature 185F
Long Term Fuel Trim - Bank 1 0.0%
Intake Manifold Absolute Pressure 16.5inHg
Engine RPM 849/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 3.0
Time Since Engine Start 39sec.
Fuel Rail Pressure 582.9psi
Commanded Evaporative Purge 5.1%
Fuel Level Input 47.5%
Evap System Vapor Pressure -0.130inH2O
Equivalence Ratio (lambda)(B1-S1) 0.987
Catalyst Temperature Bank 1,Sensor 1 715F
Absolute Load Value 31.4%
Relative Throttle Position 6.7%
Absolute Throttle Position B 15.7%
Commanded Throttle Actuator Control 9.4%
Calculated LOAD Value 34.9%
Engine RPM 758/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 15.5
Time Since Engine Start 44sec.
Commanded Evaporative Purge 0.4%
Equivalence Ratio (lambda)(B1-S1) 1.018
Catalyst Temperature Bank 1,Sensor 1 721F
Absolute Load Value 33.3%
Relative Throttle Position 6.3%
Commanded Throttle Actuator Control 11.0%
Calculated LOAD Value 38.8%
Engine Coolant Temperature 186F
Short Term Fuel Trim - Bank 1 5.5%
Intake Manifold Absolute Pressure 14.1inHg
Engine RPM 848/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 17.0
Absolute Throttle Position 16.1%
Oxygen Sensor Output Voltage (B1-S2) 0.445V
Time Since Engine Start 48sec.
Commanded Evaporative Purge 0.0%
Equivalence Ratio (lambda)(B1-S1) 0.993
Oxygen Sensor Current (B1-S1) -0.04mA
Catalyst Temperature Bank 1,Sensor 1 727F
Control module voltage 14.18V
Calculated LOAD Value 42.4%
Engine Coolant Temperature 188F
Short Term Fuel Trim - Bank 1 6.3%
Intake Manifold Absolute Pressure 13.2inHg
Engine RPM 848/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 19.5
Time Since Engine Start 53sec.
Fuel Rail Pressure 564.0psi
Oxygen Sensor Current (B1-S1) -0.05mA
Catalyst Temperature Bank 1,Sensor 1 734F
Absolute Load Value 31.0%
Relative Throttle Position 7.1%
Calculated LOAD Value 43.1%
Short Term Fuel Trim - Bank 1 3.9%
Intake Manifold Absolute Pressure 13.5inHg
Engine RPM 895/min
Vehicle Speed 0mph
Ignition Timing Advance for #1 Cylinder 24.5
Absolute Throttle Position 16.9%
Time Since Engine Start 57sec.
Equivalence Ratio (lambda)(B1-S1) 0.998
Catalyst Temperature Bank 1,Sensor 1 742F
Absolute Load Value 27.8%
Relative Throttle Position 7.5%
Absolute Throttle Position B 16.5%
Short Term Fuel Trim - Bank 1 3.1%
Intake Manifold Absolute Pressure 13.8inHg
Engine RPM 886/min
Vehicle Speed 0mph
Time Since Engine Start 62sec.
Fuel Rail Pressure 555.3psi
Equivalence Ratio (lambda)(B1-S1) 0.995
Oxygen Sensor Current (B1-S1) 0.01mA
Catalyst Temperature Bank 1,Sensor 1 749F
Relative Throttle Position 7.8%
Absolute Throttle Position B 16.9%
Calculated LOAD Value 40.8%
Short Term Fuel Trim - Bank 1 2.3%
Intake Manifold Absolute Pressure 15.0inHg
Engine RPM 876/min
Vehicle Speed 0mph
Absolute Throttle Position 17.3%
Time Since Engine Start 66sec.
Fuel Rail Pressure 556.8psi
Equivalence Ratio (lambda)(B1-S1) 1.001
New Member
Discussion Starter #20
this is
Engine RPM 636/min
Vehicle Speed 0mph
Engine RPM 630/min
Vehicle Speed 0mph
Engine RPM 849/min
Vehicle Speed 0mph
Engine RPM 758/min
Vehicle Speed 0mph
Engine RPM 848/min
Vehicle Speed 0mph
Engine RPM 848/min
Vehicle Speed 0mph
Engine RPM 895/min
Vehicle Speed 0mph
Engine RPM 886/min
Vehicle Speed 0mph
Engine RPM 876/min
Vehicle Speed 0mph
this is with the AC On.
1 - 20 of 66 Posts
