2012 sorento ex v6 3.5L
i just picked this 12 sorento ex 3.5L with alot of options. it has the codes p0300,p0301,p0303,p0305, and p0017. i know wha all the codes mean as i have a scanner. i just replace the bank 1 exhaust cam sensor and it didnt change anything. i disconnected the plug on the cam and the scanner showed it default to the requested angle the ecu tells it so im sure it isnt wiring. with it running, the live data shows the angle to be at -50.5 when it is supposed to be at +.02.
i guess the next step would be to check the timing.
... i guess the next step would be to check the timing.
Well my next step would be to check the exhaust oil control valve. But this is your vehicle and your choice.
ill look there next thanks. i havent had much time to look into the problem as im a mechanic and busy all day every day.
