Ok guys I have a 2008 spectra 5
Tell me how you can start a car and shift it in to any gear with out touching the clutch and there is no grinding gears!!! But it car won't move either.. How is this possible? Can somebody help?
Turn off the engine and try the same actions... It will shift into gears "if" there is no movement on the input shaft....
You have the same condition "if" the clutch is not releasing...
1 you can shift into any gear without grinding gears
2 you will have no movement as the clutch is still engaged (pushed in)
Sounds like either clutch parts gone or the slave cylinder is stuck.
