1 - 8 of 8 Posts
i wouldnt think thermostat as it would be an all the time deal. it would be stuck open or closed all the time not just up hills.
I dunno much bout water pumps and the radiator cap try just replacing it they are cheap could be a nice cheap fix. try with that first.
also when you say overheat does the gauge neele go all the way to the red or just up alittle?
Most likely cause is the clutch in the cooling fan on the front of the engine has gone bad. A common failure. If you don't get a loud "whooshing" noise when the temp gage goes above half then the clutch has gone bad. Replacement is approx $180 from the dealer.
Axeman (aka Sportage guru; according to KP =) )
Is that the clutch fan/viscous(sp) fan you are reffering to? I think i had that problem I was hearing this loud "airy" "wooshy" sound coming from the engine bay when i would accelerate and I had to get that part replaced a while back.
Yes, that's it.
Aloha,
I had a similar situation with my 2001 Sportage. Y(ou didn't say just how hot it was getting.) I noticed mine when the outside temperature was getting up there.
The AC wasn't as cool and the termp guage was getting warmer then usual. (usually it's always just below half.) I did a coolant flush and change and now she's just fine temp/wise.
Good Luck.
Kainui Kia
Hello guys Just for your info, I just purchase a new fan at the Kia parts store in San Juan Puerto Rico, $100.00. This was for my 1997 sportage.
If you need help I'm willing to look up any parts for you guys and you can compare prices. Nothing for me just helping.
Thanks...
MATRUCO
1 - 8 of 8 Posts
