kia forte k3 2016
i recently discover an oil spot in the garage, i have a kia 2016 AT , Q1. what could it be? a mechanic told me its the oil seal between the engine and gearbox and needs to be dismount and replace the oil seal.
Q2. do kia cerato AT has a filter for transmission fluid that need to be replace?? i shall do a transmission fluid change soon.
Please post a good quality photo, or two, at different angles and positions, of the oil leak.
That will help us assess the issue more completely and thoroughly....
If you can, get a drop of the leaking oil on your finger tip or piece of paper, photograph it, and then post it here.
We can then narrow down either engine or transmission.
