So I've posted here about the low oil/burning oil issue. I've changed out the pcv valve to see if that helps, but now i have a new issue
When I get home, I will wait for about an hour or so to go check the oil to see how things are going. I pull the dipstick out and it reads as full, almost too full, mind you this is after an hour sitting.
I clean it, put it back in and pull it out and nada....dry as a bone.
