Hi- I have a question on the 1.8L engine regarding oil changes. Just changed the oil on a 2003 Spectra with the 1.8L engine which we just got the other day. I suppose this is the same engine as on other Kias with the same displacement. When I pulled out the drain plug, I did not see any removable washer. I saw what appeared to be a fairly good machined surface step on the plug that mates with the machined surface of the oil sump casting - (possibly this step on the bolt might be an aluminum washer that is sticking to the bolt). Is there supposed to be a fibrous/paper/nylon/metal (etc) washer on the drain plug? If so, what material is it made of so I could identify it? There is a reference to a washer in the owner's manual, but I didn't detect any markings on the drain plug from washers having been used previously. On a different Kia we own, there is a fibrous washer on the drain plug, but it is also a different size engine.....
Thanks in advance for any help you may be able to provide concerning the drain plug issue.
Regards,
Bob B. (Kia Spectra 2003)
Regards,
