We purchased a 2004 Sorento, and have noticed an odor when the fan, a/c or heat is first turned on? Anyone with any suggestions? There is no odor in the car! Just from the air that circulates through!
2008 VW Tiguan (sold my Sorento)
Hi
Search the forum for this, it's been talked about to death.
Cheers
Derek
Banned
Check the drains to be sure they are not blocked. You should see water draining under your Sorento when you are sitting in driveway after running the A/C. You can buy and oder killer spray at any auto supply store to spray into the vents. If you run the fan after turning off the A/C it will help dryout the inside of your vents as this is the major cause of the oders. Remember the A/C also runs in winter in defrost cycle.
Kia Carens CRDI Mk 3
Just check the the type of fluid you are using in the windscreen
washers, somebody on another Kia forum had the simular problem
smelted like rotten eggs, it was i think in the uk, and he was using
a brand from Halfords, when they used the washers with the heater
or a/c on they got this smell.
