1 - 14 of 14 Posts
2007 Kia Sedona EX
2006 Optima base model Octane Knock. Looking to figure out why this is happening and what I can do to fix it. If I run regular unleaded I get moderate to severe octane knock going up hills. If I run super unleaded it is gone. Any suggestions?????
Not a good idea to create a separate thread for the P2138 (and omit that information from this one), when there's a possibility everything is related. You're saying there's a difference in performance when the octane is changed, but have you actually been able to alternate the gas enough times to establish that fact for certain? If it were mine, I'd diagnose/fix the P2138 and see how performance is after that, before doing anything else.
99 Kia Elan 1.8L, 17 Ford Edge Sport 2.7L V6, 15 Mustang 3.7L V6, 2013 BMW K1600 GTL
Hi All Getting a random p2138 code that resets and is fine afterwards for a week or two. I unplugged the accelerator connector and inspected it. Looked fine. Any suggestions? Thank You
Is this an issue with your 2007 Sedona EX or the 2016 Optima Base model - trying to identify which forum subsection this should be in.
2007 Kia Sedona EX
Sorry All. These are 2 separate issues. the code is on my 2007 Sedona ex and the octane Knock is on my 2016 Optima,
2007 Kia Sedona EX
I have a 2016 Optima Base Model. That is the vehicle with the octane knock.
Discussion Starter #7
2007 Kia Sedona EX
I am not sure what is going on. I posted 2 different questions. Someone decided to put them together... not sure why.
2007 Kia Sedona EX
This is the correct place for the question. Thank You. Sorry for the year typo.
2007 Kia Sedona EX
When I switch to super unleaded it is gone in five miles. When I fill back up with regular its back in about ten miles. So Yes its fact
It might help quite a bit to find out what some of the important OBD realtime data values are, particularly when the knocking is taking place. Torque for Android is the most popular, however there are others as well, including commercial off-the-shelf units.
2007 Kia Sedona EX
would changing spark plugs help? maybe a hotter plug or maybe a bosch platinum +4 type plug????
Discussion Starter #13
There would be no diagnostics behind such an experiment, and its risky.
  • Like
Reactions: Lou O.
2007 Kia Sedona EX
I installed new stock plugs and a new air filter. Not much in the way of a change. I did notice that the knock almost goes away if I put it in sport mode and lay on the gas a little more than I would like. Still puzzled.
1 - 14 of 14 Posts
