1 - 20 of 23 Posts
1998 Kia Sportage 2WD Base Model
I know you're looking for a cheap code reader/eraser but I have to show some love for my Actron CP9580A. Graphs, records, pulls PATS/Body/ABS/SRS/EOBD/OBDI/OBDII really everything except bidirectional control and you can buy online for $150 if you are willing to wait for a good deal. Retails for $279 at places like Pep Boys, Autozone etc... It has a function I don't use that much but shows the common fixes and least common fixes for a given code. Better to just use a test light or volt meter and know for sure.
2014 Sportage LX AWD, 2014 Forte LX+
Autel MS309 is the one I got and it's about US$24 shipped at this time: on Amazon.com. There is no need for a laptop or so, just plug and read.
It's not fancy but fast and as far as I can tell is a very good cheap scanner.
For codes and status it's perfect. If you need graphs etc, spend more money.
MS509 is better but is about 2x as expensive.
Caribou, Otter, Buffalo
The 309 is just a code reader, the 509 is a live Data Scanner, BIG difference..
But if you have a cell phone/tablet, for less$$ you can get an OBDII dongle and the "TORQUE" app.
.. Philip
Moderator
99 Kia Elan 1.8L
Folks need to be aware that the MS309 is solely a code reader, so if you want to tool to assist with diagnosing the fault you'll need a full scanner like the MS509.
Also there's some very cheap bluetooth ones about these days.
Also there's some very cheap Bluetooth ones about these days.
Didn't I say - for CODES and STATUS?
Yes, 509 is better but OP wanted cheap/er 'scanner', no?
Ok, there is difference between SCANNER and CODE READER.
For people who do just their own oil changes, spark plug changes, ATF changes, belts replacements, O2 sensors.. and such, MS309 is sufficient.
Moderator
99 Kia Elan 1.8L
Correct, and I wanted to point out the distinct difference difference between a 'scanner' and 'code reader'.
I come across many DIY folks that have a code reader, which does its job in listing the error code, and then find themselves wanting to progress the diagnostics further themselves, and a scanner is then the tool they want.
The code reader can do only that, read the error code - what "STATUS" does it do?
OBDII dongle works the same function as Autel scanners?
Autel scanner is a little bit cost, but really good quality
I wonder is it possible to get a obd2 scanner at much lower price but same quality as AUTEL
Moderator
99 Kia Elan 1.8L
You can access the same information with the dongle and software application.
You're unlikely to find a better deal than the Autel for a stand-alone OBDII diagnostic scanner.
My OBD scanner is old and cumbersome, and just because I like to tinker, I bought this WiFi device off eBay for $11 shipped.
ELM327 Mini WiFi OBD2 Car Code Scanner for Android iOS Diagnostic Scan Tool | eBay
It took 8 days for delivery from China to Louisville KY.
It came with a small CD loaded with bootleg copies of Torque Pro for Andriod and DashCommand for ios devices that are Jailbroken.
I tried it on the Samsung Galaxy Note, and the iPad Mini 2 and they connected at first try and worked great.
The iPad isn't Jailbroken so purchased DashCommand for $9.99
It's far easier to install "unisgned" apps on the Android.
1 - 20 of 23 Posts
