I have a 2002 kia sportage, I have to replace the o2 sensors. I need to know where i can find a diagram of all the o2 sensors for my truck. I get a code for (bank 1 sensor 1) and (bank 1 sensor 2). If someone can give me a link or draw me a diagram plz help... Thanks for the help!!!!
1995 Procharged Mustang Cobra, 2021 Sportage EX
They are on your exhaust system. The upstream one will be on your exhaust pipe near your exhaust manifold. The downstream one will be farther back, near your cat converter.
Caribou, Otter, Buffalo
It is almost an impossibility for both O2 to fail at the same time...
You need to connect a LIVE DATA SCANNER and check the actual data, do not guess and throw parts at it....
Just because it throws codes does not mean that the sensors are at fault, there are many sources of error.... Philip
