Now if you are a sedona owner like I am, and have a 3.5 liter gas engine,
You are probebly getting 15 to 20 miles per gallon , give or take.
Verry poor if you ask me. Anyway I decided to do some experiments and modifications to my SEDONA VAN , witch by the way is a gem.
Oh yea...I have an 03 SEDONA EX .
To continue here , I installed a thermometer inside the air breather , just before the filter and noticed that the air at this point was the same temperature as the outside , I also noticed that the entry at the air breather is about 3 inch in diameter and the air entry in the grill was a lot smaller , so I decided to take off the air breather system from the grill to the air breather .
The result : More power not that SEDONA needs more power.
: unbeleivable noticable fuel reduction
I have not yet calculated it yet , but I go a lot further on fuel even with higher fuel cost.
When I say farther I meen a lot farther.
Now this may work better in colder climate , but try it .
It can't harm anything...
To non SEDONA owners out there reading this tread this may also work for you , .......Good luck.......
A WORD OF CAUTION ::::::::
O NOT REMOVE THE AIR FILTER::::::::::
You will do more harm than good.
Maybe even ruin your motor..
If you have comments and or opinion and or Questions on this or anything else feel free to reply.
I'll be happy to answer your questions if I can.....
DRIVE ON>>>>>>>>>>
DRIVE ON>>>>>>>>>>
