I had a EUC update on my sorento after it malfunctioned and went into limp mode . Got it back and vehicle will not shift. So now the dealer is saying its the transmission or electrical issue. I had no shift problems prior. anyone have this happen?
Is it still at the dealership?I had a EUC update on my sorento after it malfunctioned and went into limp mode . Got it back and vehicle will not shift. So now the dealer is saying its the transmission or electrical issue. I had no shift problems prior. anyone have this happen?
Yes still at dealer. When the dealer hasn't even plugged in the TCU to diagnose the problem , calles to tell me it the transmission or electrical problem clearly has no integrity. Just saying.Is it still at the dealership?
Its a time like this that you've got to hope that the dealership has some integrity and correct it if its something that they caused with the update.
No, I haven't seen reports here of that happen.
The warranty is only 60,000 miles.Well, given it's a 2013, isn't that covered by the 10 year/ 100K mile warranty?
If it went into limp mode it was not shifting at that time. So they've flashed the ECU, likely there was an update available, the original problem is still there, so still in limp and not shifting is what I take from the info written.I had a EUC update on my sorento after it malfunctioned and went into limp mode .
I was driving on 70 loud noise from engine. Vehicle went into limp mode. Limped it home and towed it to dealer. Bergstrom dealer has a code on P1326 so they said we installed a ECU update vehicle was fine. As i got closer to home I noticed it wasn't shifting . More noticeable when you drove aggressively. So i asked my husband to take it for a ride. He was driving it more aggressive them I was. Took it to the hwy and it was horrible. Got home and call Bergstrom dealer he said to bring it in. I said i will have to tomorrow after I'm done with work. I dropped it off. They called and said this was not there when the tech tested it. I told them , bullshit!!! He said 90.00 to diagnose this is not a warranty problem. It is electrical or your transportation. I said bullshit!! I need my car so yes diagnose it. I have not heard a thing back yet.If it went into limp mode it was not shifting at that time. So they've flashed the ECU, likely there was an update available, the original problem is still there, so still in limp and not shifting is what I take from the info written.
I'd also expect codes present, did they report what codes were stored?
Bad presumption on my part, now with that story, I googled that code as I can't find it for cars over hear and not liking what I'm reading in the first instance. Knock sensor and loud noise from motor. I'm getting hits for bad conrod / bearings.The code wa h
Well update. No transmission or electrical issue. Now its the catalytic converter they claim it will cost 4625. 00 when i can have a third party replace it for 600.00. 4600.00 is more like a new engine.P1326 Kia - Knock Sensor Detection System
The Knock Sensor Detection System (KSDS) detects vibrations indicating the onset of excessive connecting rod bearing wear. It is designed to alert thewww.engine-codes.com
P1326 KIA Meaning
The Knock Sensor Detection System (KSDS) detects vibrations indicating the onset of excessive connecting rod bearing wear. It is designed to alert the driver at an early stage of bearing wear before the occurrence of severe engine damage, including engine failure. If vibrations caused by bearing wear start to occur, the Malfunction Indicator Lamp (MIL) will blink continuously, and the vehicle will be placed in Limp Home Mode. This will reduce further damage to the engine and ensure that the vehicle occupants are not exposed to the risk of a more severe engine failure. At that time, Diagnostic Trouble Code (DTC) P1326, specific to the KSDS, will be recorded in the ECU. The vehicle can continue to be operated for a limited time in Limp Home Mode, but it will accelerate slowly and have a reduced maximum speed. Also, engine RPMs will be limited to approximately 1800-2000 RPM.
Sounds better than my doomsday thoughts. SO it was blocked and loud noise was it blowing apart under pressure? You would not go near the dealer in my opinionWell update. No transmission or electrical issue. Now its the catalytic converter they claim it will cost 4625. 00 when i can have a third party replace it for 600.00. 4600.00 is more like a new engine.
No co2 censor code to prove it. The root cause is the engine but they will not fix it. Ive call Kia rep 5 times now. Nobody will help me. I have to pick it up tomorrow.
Keep it to one thread, this one!Could you please tell me more? I'm fighting with Bergstroms in Appleton and Kia to get my engine fixed right now.
No. I'm vehicle had large amounts of oil burn to engine knocking and malfunction light on to limp mode is a start of it all. Then they updated the ecu. From there they said, electrical problem to transmit problems to cat plugged. All started was the p1326 code. Engine knocking detected system due to bearings wear is the root problem. Burning oil will plug the cat. Why did there tech find it when the drove the car?Keep it to one thread, this one!
Are you suggesting that its gone from "not shifting" to the "engine needs fixing"?
What's with your choice of thread title and everything you've posted at the start of this thread?No. I'm vehicle had large amounts of oil burn to engine knocking and malfunction light on to limp mode is a start of it all. Then they updated the ecu. From there they said, electrical problem to transmit problems to cat plugged. All started was the p1326 code. Engine knocking detected system due to bearings wear is the root problem. Burning oil will plug the cat. Why did there tech find it when the drove the car?
You just need a good locally trusted technician I think, they're out there somewhere.
