2001 sportage ex 2wd, 2002 Grand prix GTP (for now) 2015 Jetta SE (soon with more boost)
Hi, My power steering pump seems noisey to me. I can hear it inside the car, its louder than the engine. Can you guys tell me if this is normal to the V6 sportage. or if i might wanna look into a fluid flush.
2009 Sportage LX V6 4WD, 2011 Mack GU813 405M
If you haven't already, just make sure there is fluid in the reservoir. If it has been run dry, then you might be in trouble. If it is low, top it up and run it a bit to see if the noise gets any better, not gonna make it any worse. Start simple, work towards hard.
It sounds like it is running low on fluid. Add some fluid and see if it goes away. Make sure to use the fluid specified in your manual (probably PSF3).
It has full fluid, I even topped it off with some PS conditioner fluid, no difference.
Has full fluidm, even added some lucas PS fluid with conditioners. it does have 135k miles on it.
