1999 Kia Sephia
I need to know which wire goes to the turn signals. All other signal lights work fine, ie: tail, parking, brake, reverse, hazards...its just the turn signals. Please, help!
Blown turn signal fuse (10Amp) in passenger compartment fuse box, Bad turn signal flasher module or bad turn signal switch (lever)
could you be more specific?
is it only the ONE turn signal that does not work? or all of them? left or right? front/rear?
Or, the very odd. Are both bulbs blown? Sounds like it couldn't happen, but I just got pulled over last month because my wifes saturn had no plate lights. Replaced both, they worked.
I though, oh god, here's a wiring issue. But, start at the easiest to check, then work your way to the wiring.
Thank you all very much for responding!
It is all turn signals which are not working. The fuses look good. Where is the relay for the turn signals located?
