KIA spectra 5 2006.
So the other day the AC on/off button stopped working(no power or light when pressed), and the fan control does not work at all. basically no power to the center power console. The radio works fine and so does the rear defrost button. I did check the AC fuses and they look OK. I do not have a volt meter to test the circuit. Would there be a relay or circuit breaker somewhere else that might cause this?
Also, at the same time the airbag light went on. The car only has 39,000 miles.
So i am thinking that there is a power failure somewhere that covers a couple of things. Ideas?
Thanks in advance for your help...
Figure it out
Apparently my son had pulled the radio out and when he put it back in he did not realize that 2 connectors were not connected. We reconnected them and all is well.
