g37x
hello guys,
i have a 2010 borrego v8 and came in with no cluster operation with check engine light on with code b1613 lost communication to clu
I tested all the fuse, tested all the wiring from dlc to cluster, from IPM module to cluster, Power side to cluster, ground side to cluster and all of them are fine. but i have no cluster operation No lights, speedo, rpm and other gauge are working. the onlly thing that lights up are check engine light, and airbag and immobilizer.
anyone one here experienced this kind of problem or have experienced fixing this before? or you guys think it will be the cluster? :(
new cluster are 4000k according to kia dealership here in canada
15 K900, 13 Sportage
Yep most likely the cluster...and KIA will send it out to have the mileage programmed into the new one takes about 3 days
g37x
I checked those.. the problem here is mine is KM not MPH also they have temp gauge mine doesnt. so Im worried if i buy then and the pin connector dont fit.. do know guys know any place or site where i can get them for KM/H
thanks
