600RWHP HSV MALOO /SPORTARGE platinum TD
HI
on the way home this morning the turbo diesel kia lost most of its power ,will only rev to 3000 rpm, and won't change up to 4 th gear unless you lift your foot
wont rev over 3000 in park
just seems like it is getting no boost pressure
any ideas where to look to start with ??
no engine code lights on the dash
haven't put a scanner on it yet
first problem we had since we owned it over a year
thanks
What does the engine sound like? Rough? Is the timing still intact?
yes every thing was fine it threw 2 codes but ran fine only reduced power and rpm
I found the problem :D
rats had chewed threw the fuel pressure sensor plug ,:eek: so not reading any fuel pressure ,so no boost
soldered the plug back on the wiring harness and cleared the codes
ALL GOOD NOW , saved $2,500K FOR a new harness :D;)
