1999 kia Sportage 2.3l long stroke modified ,2005 Magna 3.5l,2006 nissan navara d22
Hi Gents,
Have finally got around to rebuilding my knackered sporty engine,but encountered some problems in the removal.the major ones being the 4 bolts behind the head in front of the firewall.
The lack of space was a shocker for any tool I had .Also it was the first time these bolts had been cracked it was on the edge of my physical limitations.
there was only one thing I did not do and that was to take out the main engine mounts and control the amount of sag with a jack underneath.
In the end I ripped the head off to gain greater access but i would prefer to have the head and timing all assembled prior to installation of new rebuild.
Any use full comments ,happy to receive them.
regards Dave:D
Dave,
They are a total pain to get to. It may help to remove the motor mounts and lower the engine a little. The other thing you can do is loosen the body mount nuts and lift the body 2" to get at them.
I hired a guy that I worked with that had small hands and he was able to reach them.
Good luck and keep us posted on the build.
UPYOURKIA
nghtmare engine removal
Thanks for the comments upyourkia I,ll take a look at the front body mounts tomorrow .I was planning a little body lift but not so soon.
regards Dave
Anyone dropped the engine in as a full assembly before?
