Hello all, Electrical question here for my 02 sportage
My dash lights do not work. More specificly, My speedometer, RPM, Gas etc. are the ones that are out. Everything else works, Check Engine light(haha) Signals, clock, hazards all work. I have noticed that sometimes, they will be on when I start the car, once I get going they will turn off/turn on. Sometimes even flash. Is this a fuse issue???
Also on a Turn signal note. I've pretty much rumaged around and found out my turn signal issue (it Flashes too fast) My question is I'm a DIY type of gal, when looking for parts I've seen instances where I have to replace the whole assembly and I've seen where I can just replace the bulb. Which one?
Thanks for all help!
Caribou, Otter, Buffalo
Dash lights, check for loose connection at rear of cluster..
Fast flash signal, check all your signal bulbs..
... Philip
