1 - 20 of 22 Posts
2018 Sportage SX Turbo Black with beige interior
The new software update is available to download from the website.
2017 AWD Sportage SX Black Cherry/Beige
Just added E538(USA). For me this release had updates to my neighborhood streets so I was glad to get the update. Cant go wrong with free updates and the Nav (D/L -UPTE SD) program works slick.
What's the website? Does it still take a long time and can you drive without the radio on while downloading. I can't remember what I did last time but it did take about a half hour.
It seems too soon for an update.
SSportage its the free app you download and install on your PC and then run from there to load up your SD card(32Gb, no longer 16GB). We have been using it since last year. The upgrade still takes around 25 or 30 minutes as you remember to install in your headunit..
Is it the same update we did last year? I paid for the last one. I'll try to check my version today and check back here later.
Thanks Fred
Here is a pic of the app once you select your vehicle. On the bottom notice the "Notices" area circled. Its dated on the right with the date it was added to be available. Click on the + and further info about the update is presented.
2020 Sorento SX, 3.3L AWD
Downloading it now for my Sorento. It keeps getting bigger, now it takes a 32gb card. :D
2017 SPORTAGE SX
Just updated not so good. I have the radio info taking up about 25% of the screen. I would press the home button and it maxs out the nav screen. Not doing it now.
2019 Sportage SX AWD
Just finished our 2019 SX. Looks good both on radio and nav. Will have to play with it a bit to get the screen settings exactly like my wife wants it, but so far, so good.
99 Kia Elan 1.8L
Using the below link, please add location and vehicle (year & model) to your Profile/Account Details
eg.
USA
Account Details
Forum Rules
2017 Kia Sportage SX
I've never done an update on my 2017 Sportage SX so I have a few questions. First, does the DL contain the new firmware or do I need to download them? Is the update just map updates or does it change functionality and/or look and feel? If so, exactly what changes? Any way to preview? If I use a new SD card and do the update, can I put the prior SD back in and revert to the prior look & feel just in case I don't like the new (if there is new)? I did some reading and it seems to imply the car must be running throughout the update or roughly 30 minutes. Is that correct?
.System and map updates.
I do not believe you can revert back to what you had by putting the old card back in.
Changes look and feel
Yes the car should be running or what a lot of us are doing is attaching a battery tender to the vehicle as it is upgrading.
First update takes the longest
2017 Kia Sportage
You can just run the car, or you can drive it as long as you don't turn it off. Most of the firmware changes are pretty minor with a few added features. I haven't noticed any interface changes of the years (I also have a 2017). You can't revert back because most of the firmware changes remain in memory. I've always done the updates and have had no problems.
Thanks for the help. I did the update today and all went well. This was my first update of my 2017 Sportage. The Battery Tender suggestion made the update easy.
2020 kia sportage lx awd
Is this update just for those who has nav and controls for heating etc? Not sure if there's a diff for base models..
My last update I didn't run the car, just turned the ignition on. It really didn't make a dent in the battery charge in the half hour, just don't leave your lights on and you don't need the engine running.
2018 Sportage EX
I'm curious too. Don't have nav but would be interested in updating the head unit. I don't want brick my unit by trying when it won't work anyway.
The majority of these free updates have to do with Nav. Any "system updates" are mostly cosmetic and head unit related. The last system update of worth was when they added Carplay to our units back in late spring early summer 2016. Others here may remember others.
1 - 20 of 22 Posts
