Hi Ya'll
I picked up a set of seats from a burrego for my 1957 Willys project. There are a ton of wires in the front seats. The only ones I have been able to identify are the air bags. I'm sorry, I cant supply the year. I was only able to identify them by images on the net.
Anybody happen to have a schematic handy?
Thanks
Casey
09 Borrego EX V8 2WD
Hi Ya'll
Thanks
Casey
These might help. BTW, it's Borrego
Havasu,
Thanks for the info but unfourtunately it isnt enough for me to figure it out.
There is a seat memory ecu under the seat that is complicating matters. Inside it are relays as expected but there is also plenty of solid state garbage that i can ony assume is the memory bit. The switches on the side of the seat feed into this unit. I was able to identify the main ground and power wires. Running power to them did nothing. It seems that the solid state portion of the board runs off a seperate power input other than the larger wires designated for the seat relays.
I have learned enough about the unit to eliminate this box with relays. I would rather avoid this though if all i need is a full schmatic. Can anyone help? Thanks
Casey
Havasu,
Casey
Maybe there is something in this that will help.
Thanks, with your info i was able to make the passenger seat work
I think i may have a different year than 2009 as the driver seat is different than shown
It has an additional memory module 95450-2j000 under the seat that is not in the schematic. The seat switch is also wired differently. Instead of 18 wires it has 9. These 9 feed into the memory module. The output of this module goes to the motors.
Im sure if i can figure out which wires go to the power end of this module under the seat i can make it work
If i cant, ill end up rewiring the whole dand seat and bypassing this module. Id rather not!
