02 Rio base model, just did my 2nd oil change, used same FRAM filter that I did last time. Only difference is I used Valvoline (not sure if this makes a difference for my issue) I made my 80 mile round trip to work twice. Today I started my car, and it was fine. Put it in gear, and got to the end of my driveway where I (as usual) put it in neutral so I could coast down the hill to the end of the road. I hit a little bump in the road, heard a metal on metal type of clang, and my car shut off. Tried turning it back on, but it didn't want to start. Sounds like it's trying to fire every once in a while, cranks fine, motor shudders (bad mounts i think). Any ideas on what it might be? Doesn't sound any different on the 1st three cranks (normally fires right up after that), but past that it sounds like the battery gets weak really fast.
Any ideas or recommendations would be helpful and appreciated, thank you.
