I found a Pistola...! Queensland Motor Recyclers (07 3274 4200) shipped me one down...but remember you either need the liner, or a piston with the appropriate size code. In my case all were size D...and that's luckily what I got. Thanks Jason. Remember you can't mix up con rods either as they have a weight code and big end bore code. Be prepared to spend $68 on a piston/conrod (plus postage) and the same again to fit it. The con rod has to be heated to facilitate gudgeon pin removal.
