Had a hitch installed and noticed days later they broke the lower holding clip on the tail light. Does anyone know where to get one or do you have a damaged assembly where the clips are in good shape. These are the clips that fit into the holes on the metal work before you attach the two screws.
Go to your local Kia dealership. There are .85 cents each. Kia part #,86910 22000.
Strange, they said they cannot order this part. I will take that part number and try again, thank you very much.....Bob
Cobra, just checked out that part number on the web and I might have given you the wrong impression. It is not the retainer for the screw that I'm looking for but the plastic pin attachments on the right side of the lamp assembly that push into a circular metal tab. They hold the outside portion of the light in place, then you screw the other side of the lamp in place. These holding clips you cannot see on the image that the part number came from.
