so i have a 2004 kia rio, live in canada, so daytime running lights are necessary. but what doesnt make sense, whenever i drive, regardless of whether my headlight switch is set to "off", all the lights come on as if i turned on my lights (like how you would drive at night). normally, shouldn't only your drt lights come on if your switch is off, with the all the other lights off?
i just got the 04 rio last year, so i'm not sure. a
also the low beams are incredibly dim, at night, it sometimes seems like i dont have low beams unless i go into a completely dark area..
Some thing's to check, Faulty DRL unit, headlight or Tns relay or a bad ground somewhere (dim low beams lights). You should only have low beams and not all the other lights on during the day. Good luck with it and keep us posted, Reguard,s Ronjohn
thanks for the reply. i'm not good with cars, i was hoping it was something simple like a fuse. i'll just have to live with it - a costly repair isn't really worth it being that the car is old anyways.
