Hi,
After bleeding the brakes on my 2001 2 door 4x4, looks to be non ABS, the brakes are mushy as could be. Rear does not lock up ( even on wet grass, front will) when I do a panic stop and pedal almost to the floor.
Bled by starting furthest to shortest line, engine off 4 quick pumps per the held down.
After no success I replaced the master cylinder (bench bled) and rear wheel cylinders they were rusty in bore. Went thru same bleed process.
However when I do a quick 4 pump while doing a panic stop rear almost locks up, I bled a quart thru the system.
And it still does it and suggestions?
