It's been a while since I posted on this forum (got a bid fed up with certain aggressive users). Anyway, he's hoping you're all friendly again....
...so...my question. My car is approaching 3 years old, still under warranty. Do I have to present it to the dealer to take it for it's first MOT or can I just use any MOT garage (to maintain the warranty)? Experience suggests that it costs more to use the dealer as they simply mark the price up to the maximum they're allowed to charge. Also, can I present it 28 days early and still have the original registration date honoured (you know you can have a car tested before the expiry date and have the original renewal date honoured).
The dealer I use and some others offer a free MOT with a service. So it may be worth to shop around. I would get the MOT done at a Kia dealer though as any issues they can just plan in the warranty work straight away without any hassle.
No car today should fail its first MOT providing you check the basics before you go i.e. lights, horn, wipers, washers, tyres. Saw a survey a while back that listed the reasons for failure, just listed them above, why don't people do simple checks before taking the car, just realised, they are muppets.
Since carrying out an MOT entails no work it simply cannot affect your warranty but should it happen to fail on say a suspension bush which is a warranty item you would have to take it to a Kia dealer to get the work done and then return to the original garage for a re-test which is a fair bit of hassle.
Since Kia's tend to be service every 12 months or mileage (depend on the age and engine) its odds on that the MOT will be due when a service is due (unless you do an annual mileage that makes your services due at odd times). Ours is 3 years old in September and will have the MOT while the service is being carried out. One visit and theoretically no hassle. I could save a tenner going to the garage up the road but is it worth the 2 hours or so of wasted time involved.
Cars are due an MOT test on their 3rd birthday and every year after that.
Originally it was just a simple enough safety check but as time as progressed more and more items have been included. Emmisions have been included for many years now and more recently things like non-standard headlight bulbs should be checked for legality.
My first few cars which at the time passed with no problems would not get past the door in the current test.
Older cars are not subject to the most modern set of tests e.g. one of my cars is considered to be pre 1978 and is only checked visually for excess smoke rather than having to comply with the more strict rules. In truth it would pass the rules for a pre 93 car but would fail the later requirements since it does not have a cat fitted.
Not correct. If it was many BWM's and Merc's would fail. Tyres have to be the same size across an axle, does not matter if they are the same front and rear but I think it would be an advisory if you had bigger on the front (some old Citroens did).
I had a car about 10 years ago with 195 50 15 front and 205 50 15 rear, passed many an MOT.
The most important fact is you must inform your insurance if you change size form the OEM fit, if you don't and have an accident you may find yourself without the cover you thought you had.
OK, I miss understood then. Thank you for that. That was what it was on my clio,front nearside was a 65 and offside was a 70. That makes more sense now.
There is a French equivalent called the Controle Technique. It starts at 4 years old and is repeated every 2 years. One crucial difference is that test centres only do testing and are completely seperate from repair garages by law.
Thanks for all your friendly replies. The only reason I asked was because I've never had a car still under warranty at MOT time. I've considered the argument of hassle free MOT by using the dealer (in case of warranty work) but also considered the lower cost of using an everyday MOT garage. I guess I'll have to see how much the dealer charges before making a decision.
My services are dictated by mileage, not time so a routine service wouldn't coincide with the MOT.
If you don't take it to a Kia dealer every 12 months you won't get the body check carried out and the book stamped. Without those no paint/body warranty.
Its normally free at a Kia dealer, we have never been charged.
My services are more frequent than 12 months as I do more than 20,000 miles per year. Does that make it OK with the body check? I could get off my backside and check my service book but I'm nice n comfy at the moment! I'll try and remember to check tomorrow.
I believe the body check is annually rather than mileage related so if you do lots of miles it wont be done at every service. Just had a 50k service on my 09 car and it had a body check, no extra cost.
Funny how we've gone a little off topic. I've checked my service record book and can confirm I've had a bodywork inspection with every service (so at least every 12 months).
mot test is required if you car is 3 years old from its manufacturing date. Other vehicles 3 years or older are required to have an mot yearly. It is advised to have a service every 6 months if you do over 6000 miles and every 12000 miles 12 months should be your next service.
Where is it advised to have a service every 6 months.
Kia service intervals for our MY2011 Ceed SW CRDi are 12 months or 20,000 miles (whichever comes first), ours is always 12 months @ approx 12,000 miles. If it was a petrol it would be 12,500 miles or 12 months.
Servicing every 6 months has not been necessary since the 80's. The last car I had with 6 monthly intervals was a 1984 Escort. Modern oils will have no problem with the recomended intervals providing the garage uses the correct spec long life oil.
My BMW needs servicing when the dash says, had it 5 years and its been serviced twice.
Servcing every 6 months is just throwing money away.
206.7K members
