1 - 9 of 9 Posts
2000 Kia sportage 4x4 4dr
i have a 5spd now and want to put an auto in. what would i need to do this. mine is a 2000 4x4 4dr.
'02 Sportage 2 door.
Quite honestly you would be better off just selling your current Sportage & buying one with an automatic.
For starters you will need a transmission cooler. Supply & return lines. ECM from an automatic Sportage. You will also need to to swap your brake master cylinder and possibly your pedal assembly.You might also need a transfer case from an automatic Sportage. Plus who knows what else.
well i am willing to do it..i am building a crawler out of it and i want the auto tranny. if i did not already have stuff done to this one i probably would just trade it for a auto sportage.
heres what i am thinking i will need...
1)ecm for auto tranny
2)auto tranny
3)brake master cylinder
4)tcase?????
5)pedal assemblie???
this look about right?
Don't think you'll need the auto master cylinder if you plug the line but it would be cleaner with a new one.
You will also need an ecu from an auto.
Best bet would be get a wrecked 4x4 auto so you have everything you need.
Take pictures and post them!!!
UPYOURKIA
ok thanks will do. on 4x4wire i was told the ecu's are the same? is this true?
I know ecu's are different, otherwise why would the one I have say AUTO on it???
Discussion Starter · #7 ·
thanks. gonna start check the j/y around here and getting parts together
Other things may be wiring for trans to ecm, speedometer from auto, and wiring for neutral safety switch and shift indicator lights on speedometer.
UPYOURKIA
Discussion Starter · #9 ·
ok thanks i probably just need to find a wrecked one to get the swap parts from.
1 - 9 of 9 Posts
