Status
Not open for further replies.
1 - 1 of 1 Posts
1999 Acura Integra
heres a Maintenance Schedule if u dont have one
Months Kilometres Maintenance Type
4 months 6 000 km Maintenance #1
8 months 16 000 km Maintenance #2
12 months 24 000 km Maintenance #1
16 months 32 000 km Maintenance #3
20 months 40 000 km Maintenance #1
24 months 48 000 km Maintenance #2
28 months 56 000 km Maintenance #1
32 months 64 000 km Maintenance #3
36 months 72 000 km Maintenance #1
40 months 80 000 km Maintenance #2
44 months 88 000 km Maintenance #1
48 months 96 000 km Maintenance #3
52 months 104 000 km Maintenance #1
56 months 112 000 km Maintenance #2
60 months 120 000 km Maintenance #1
64 months 128 000 km Maintenance #3
68 months 136 000 km Maintenance #1
72 months 144 000 km Maintenance #2
76 months 152 000 km Maintenance #1
80 months 160 000 km Maintenance #3
84 months 168 000 km Maintenance #1
88 months 176 000 km Maintenance #2
92 months 184 000 km Maintenance #1
96 months 192 000 km Maintenance #3
100 months 200 000 km Maintenance #1
104 months 208 000 km Maintenance #2
108 months 216 000 km Maintenance #1
112 months 224 000 km Maintenance #3
116 months 232 000 km Maintenance #1
120 months 240 000 km Maintenance #2
124 months 248 000 km Maintenance #1
128 months 256 000 km Maintenance #3
MAINTENANCE #1
MAINTENANCE #1 INCLUDES:
Replace engine oil and filter
Check fluid levels (pwr. strg., brake/clutch, coolant, washer)
Check tire condition and pressure (including spare)
Check exterior & interior lights for proper operation
Check windshield washer/wiper function
Check horn function
Check handbrake function/freeplay
Lubricate all latches, hinges and locks
* = if equipped
See "Model-Specific Maintenance"
^Top
MAINTENANCE #2
MAINTENANCE #2 INCLUDES:
Check horn function
Check engine coolant specific gravity
Check engine air filter; knock out dirt/bugs, replace as req'd
Remove wheels and brake drums, check pad/shoe thickness; inspect calipers, cylinders and shoes for proper function, leaks or damage; adjust rear brakes as required.
Rotate tires
Visually check underbody fasteners for condition & integrity
Check brake/clutch pedal freeplay
Check steering wheel components for proper operation
Check CV boots/tie rods/ball joint boots (visual inspection)
Check all seat belts and anchor integrity
Check exhaust sys. for leaks, mountings, brackets; heat shield
Check transfer case oil level & condition, fill as required
Check front & rear differential fluid, fill as required*
Check man. transaxle oil level & condition, fill as required*
Check auto transaxle fluid level & condition, fill as required*
Lubricate driveshaft u-joints (early Sportage only)
Road test vehicle
* = if equipped
^Top
MAINTENANCE #3
MAINTENANCE #3 INCLUDES:
Check horn function
Check coolant specific gravity
Inspect, deglaze, clean, adjust & lubricate brake components
Rotate tires
Check transfer case oil level & condition, fill as required*
Check idle speed
Inspect power steering lines & hoses (visual)
Check A/C compressor operation and performance*
Check brake line fittings, bleeder screws, booster for damage, looseness, leaks
Road test vehicle
* = if equipped
^Top
KIA MODEL-SPECIFIC MAINTENANCE
In addition to the KIA Basic Scheduled Maintenance, certain KIA Models will require the following maintenance services:
ALL MODELS
(Every 36,000 km or 18 months)
Manual transaxle service (except Sportage)
Automatic transaxle service (except Magentis)
Check drive belt condition & tension
Inspect front ball joints
ALL MODELS
(Every 48,000 km or 24 months)
Replace engine coolant
Replace engine air filter
Inspect fuel lines & connections
Inspect ignition wires
Replace spark plugs (except Platinum)
ALL MODELS
(Every 60,000 km or 30 months)
Replace brake/clutch fluid
Inspect EVAP canister & vapour lines
ALL MODELS
(Every 72,000 km or 36 months)
Replace fuel filter
Inspect PVC system/hoses for integrity
ALL MODELS
(Every 96,000 km or 48 months)
Replace spark plugs (Platinum)
ALL MODELS
(Every 102,000 km)
Replace timing belt
SPECTRA
(Every 12,000 km or 6 months)
Replace HVAC air quality filter (if equipped)
MAGENTIS
SPORTAGE
Transfer case, differential & manual transaxle service
Transfer case & differential service (auto. trans. model)
SORENTO
1 - 1 of 1 Posts
Status
