You're not blind. The front suspenison has no lube points. The ball joints are sealed.
There are lube points on the drivetrain. The slip joint on the driveshaft near the transmission has a grease fitting. There MIGHT be grease fittings on the u-joints. That depends on the supplier Kia used. Some do, some don't.
